going LSD soon!!!!!!
DRIFTKNIGHT_240
Car: 240sx Zenki s14 [going sideways]
1st just wanna know wat u guys think ,am pretty sure wat is a lsd but i wanna make a detaied thread about it ...I got a 300zx diff and j30 axles ,, all that together cost me $91 bucks . Yea i know i got a lot to have done in my car before i can drift but i think this is one of the most important upgrades of all , then am going to get hks coilovers.., and later on built me a KA-T ... My dream is like everybody here on NICO i suppose to get experience before smashing any streetlight or dumbster lol ,, and share my experience as well ... =/ps : pic coming up during the week ..!
Modified by DRIFTKNIGHT_240 at 9:21 PM 6/7/2009
Modified by DRIFTKNIGHT_240 at 8:37 AM 6/10/2009
T1ghtJDMDRIFT
Car: Back Seat Banger
DRIFTKNIGHT_240 wrote:
If you don't know, you aren't ready.
NismoZRS
Car: 92 S13 Coupe
good advice..
also, you should know how to do 180 and 90 degree turns before you learn how to have the car slide out more by pressing the gas.. if your not used to the rear sliding out by itself or e-brake.. your deff arnt ready..
but anyways.. good luck
MastaYu
Car: 92 Nissan 240SX SE HB
MICRoS13
Car: 200sx 98'
Lol try looking into the j30 or s15 hlsd i heard those are the top choices. If i'm wrong i suggest the search bar
nevertheless
Car: 1993 240sx hatch
1995 Nissan D21
ssshhhhhuuuuuurrrrrreeeee you are.
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
Dont do drugs!LSD can have long lasting ill affects on the brain. if your lookin to get messed up, a nice stiff drink should suffice.
RCA
DRIFTKNIGHT you should ask a question when starting a thread.
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
Why not get an LSD out of a S13 and bolt it right in (All Hicas Models have LSD) Thats where I got mine same 6 bolt axles as stock.
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
help with what? unbolt axles, driveshaft...place jack under differential unbolt slide forward and lower....place new differential on jack, repeat the steps in reverse and your done
DRIFTKNIGHT_240
DRIFTKNIGHT_240 wrote: 1st just wanna know wat u guys think ,am pretty sure wat is a lsd but i wanna make a detaied thread about it ...I got a 300zx diff and j30 axles ,, all that together cost me $91 bucks . Yea i know i got a lot to have done in my car before i can drift but i think this is one of the most important upgrades of all , then am going to get hks coilovers.., and later on built me a KA-T ... My dream is like everybody here on NICO i suppose to get experience before smashing any streetlight or dumbster lol ,, and share my experience as well ... =/ps : pic coming up during the week ..!
White Comet
Car: fc, s13 and mazda6, Sierra
lsd huh? you'll be tripping balls, man
Spiffy240
Car: 1992 White 240sx Fastback SE
if you want to drift your car, you should not have went with a oem lsd...
you should get a 2way lsd from either kaaz, nismo (not street version), tomei, etc. if you want to drift the car.
slidestyle69
Car: 92 s13
that is true, but for right now a oem vlsd will suit his needs. i drift a j30 and i do quite well with it. A shim job might even be something you(diftnight) might wanna look into.
White Comet
i shimmed mine and cant wait to have it on the road
DRIFTKNIGHT_240
hey man does ur axles from the j30 one is a lit bit small than the other one?
can u tell me which one goes to wat side of the diff?
slidestyle69
Car: 92 s13
I use a j30 diff and using this u dont have to change the axles. Thats what u should had done, It would had been so much easier and really there's not an advantage to having a zx diff over a j30. the gear ratio's are almost identical, depending on which model zx ur diff is out of but Sorry i dont have any info on swapping this out. search it up with the search bar and see if u can get a write up about it
adrianfromthecastle
Car: 1992 Nissan 240sx
DRIFTKNIGHT_240 wrote:hey man does ur axles from the j30 one is a lit bit small than the other one?
Bolt up the diff first, then you'll see which side goes where. (I think the shorter side is the passenger... but then again, its been awhile)
fyi... vlsd sucks for drifting. Its lots of fun in the rain... but on a dry hot day... you'll wish you went welded.
slidestyle69
Car: 92 s13
of course bc its a vlsd, but with a nice shim job its not to shabby. my j30 has kicked open only a handful of times when i was drifitng on dry pavement, really i believe if u get a worn out vlsd then its gonna suck but if u get one that hasnt been abused really then it works nice. For a daily driver welded SUCKS i done been down that road
MICRoS13
Car: 200sx 98'
so what's the best LSD someone should go for cause everytime i search, welded lsd's and some say the hlsd off the s15 is the best way to go but im looking for what suits atleast 480hp daily driving some drag maybe drift and idk if this is stupid but im going to build my sr20 to handle high rpms and late shifts so what's the best gearing to and i probaly didn't make sense cause for a i know the hlsd could be welded and not viscous like i heard the z32 & s13 lsd's are.
White Comet
if you plan on sliding at all dont get an hlsd
MICRoS13
Car: 200sx 98'
Alright... so i guessing j30 rear diff?
slidestyle69
Car: 92 s13
well if ur short on money and cant afford a real lsd then go with a j30, its direct bolt in on a s14, s13's just swap the back plate and i believe longers bolts at the front, but what i have done is put the 180sx ring and pinion in mine so my gearing is 4:36 .....My car is launch happy on a drap race and when i slide it, It lets the ka really put the torque down. On wet roads i can clutch 5th and spin easily with 15's, 17's i still can but not like the 15's or 16's
33alez33
Car: 1992 240sxse
No matter what anybody says going with any type of LSD is better than an open diff. Just avoid that Lucy in the Sky with Diamonds stuff, it will make you the wrong kind of drifter.
On a more serious note my factory VLSD doesn't feel too bad at all, its awesome in the rain and during spirited driving but occasionally when the friction difference between the tires is huge it doesn't do well. I'm pretty sure you will love the difference and for $90 you couldn't have bought a better mod.
MICRoS13
Car: 200sx 98'
Lol well i don't pay bills at the age of 16 and bring in 2$ above minimum so saving up for the right lsd isn't a problem what about the kaaz lsd how are those?
slidestyle69
Car: 92 s13
ive heard good things about the kaaz lsd's
White Comet
tomei's feel really nice if you've gotz da monay
adrianfromthecastle
33alez33 wrote:No matter what anybody says going with any type of LSD is better than an open diff.
LOL... I don't think I've ever heard anyone say that an open diff is better than anything else.
MICRoS13
Car: 200sx 98'
Okay so i saw on a couple websites the tomei lsd are worth $850+ which isn't bad since i want this car to have the best even if money's tight. but they were asking open diff or viscous so i was guessing the best way was this tomei lsd with the maybe z32 rear subframe? or keep it s13 ?
Driftsamurai
welded is awesome! i daily drive welded no problem
