PapaSmurf2k3 wrote:Do I need a fuel pressure regulator? no, the e-manage will do just fine.
Are there any nice websites to find 370cc injectors cheep.
nope
For the greddy e-manage, do I need everything (injector harnesses, and support tool?)
you will need the support tool, since you have a laptop, the other harnesses are optional, I will however recommend an ignition hardness, so you could control the timing.
and after I get the e-manage, will I still need a boost controller, or will the e-manage be able to control that? I have a laptop to program, so that is no problem.
the e-manage can't control the boost, so you will need a boost controler
That is incorrect, When you richen/lean the mixture you are adding/reducing fuel.NISSANBluebird wrote:Checkered-Member,
http://www.altimas.net/forum/s...ber=2
Cthunder: " actually you do need an FMU, the emanage cannot ADD fuel when you boost more. the FMU will add fuel in a 12:1, 10:1, 8:1 or even a 1:1 ratio to boost. you WILL run lean at top end if you do not run an FMU. the Emanage CONTROLS fuel while the FMU ADDS fuel."
C-Kwik wrote: I will correct him in that forum as soon as my account is activated.
fiznat wrote:c-kwik you even removed your factory FMU?
see this is something that I was wondering about... I have 50# injectors and I plan to boost something around 15-20lbs- I think I'm gonna end up maxing out before I get all the way up there. ...But you're even taking off your stock FMU? Whats the fuel pressure like if you dont have that on??
NISSANBluebird wrote:Originally posted by huguetpj "]I wouldn't even bother... as it was posted on the other forum that guy just needs to have the last word![]()
I agreed , C-kwik there are no point to talk to him, let him be with his FMU+ JWT + SAFC +720cc . JWT never met to use with FMU , there are no need for a FMU, period. that dudde like to brought it up because he thinks he knows everything. I just want to prove that the newer model Altima can be turbo because they are the same Ka like any other one , I don't mind if JWT dont' make anything for it, but there're other alternative to manage the fuel system.
Well, I just finished posting there. We'll see how he responds. This should be fun.
nismo1003 wrote:if u want to spend little more, i would suggest u to get a E-01 w/ boost controller, then u don't need a laptop , no need to buy the 100 bucks cable / software . that may save u little more
