Eh.. my bad on the z32 mafs. You can get n60 mafs pretty cheap ( <20$ on ebay) so if they are capable of 300hp thats a real good buy for the build.IWannaS15 wrote:Nelson, all Z32s (NA and TT) had N62 MAFs. The N60 comes from the Maxima. Ive heard its capable of 300-350whp. I never seen an exact number though. I think everybody's just guessing based on Maxima supercharger kits at that power level retaining the stock MAF.
I kept saying N60 instead of N62 in your thread about the J60.
Simm, I think the SAFC is a good bet. If you stay under 7-8psi, you shouldnt have to worry about timing.
I agree. If you want to stay cheap, maybe get a rebuilt Z31 turbo which is basically an old T3 60 trim with .63 a/r turbine; a pretty standard choice for low boost KA guys.j-z wrote:a straight t3 would be a good choice especially since alot of them come stock on nissan motors and can be had easily and fairly cheap.
no. you only build boost when there is a load on the engine. my turbo gets to full boost at 2600rpm. but when i'm rolling at 80 on the interstate at a constant speed, my car runs in a 10-12 in/hg vacuum. when i get on the throttle a little bit i can build a little boost or full depending on how much throttle i give it.kornaz wrote:Sorry to hijack the thread, but i am planning on running a T3 .50trim 63A/R turbo on my S14. And @ 70mp/h my rpms are 3K exactly. So if the full boost is @ 3K rpm, then i would be boostin all the time?
