compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Sat Feb 25, 2012 10:15 pm
You won't be able to hold 19 psi to redline with the stock actuator. Boost spiking doesn't have anything to shoo with the actuator, its caused by the turbine housing being to small, and exhaust systems that don't have enough back pressure. Usually rule of thumb is a actuator can reliably hold boost that is double the spring rate to red line with a boost controller. I am running the gt3071 with the hks actuator and it won't hold past 23 psi with duty cycle at %100 on my boost controller. To get more out of my system im going external wastegate.
