um..RUDE! i did and didnt find anything solid/concreteso if someone could actualy be constructive and help that would be BOSS!King Ranzo wrote:Umm. Heard of something called the search button?
Seriously bro. If you didn't use it, use it now. If you did and had no results, then I suggest Google.
He's gonna need wiring harnesses and motor mounts as well. Can't just plug n play with ECUs.fastass wrote:you should be fine with the ecu and motor. no more.
Sorry about that. Thought you'd be one of those newbies who just came in looking for answers. We get so many of those in here, it's hard to tell who is smart and who's a doof trying to be fed answers. To prevent a repeat of something like this, I suggest stating in your OP that you utilized the search button, that way you don't get flamed.nismobenzo wrote:
... if youre going from a sohc to a dohc shouldnt it beKA24DE>KA24E? just sayingg...nismobenzo wrote:so im swapping out my old 230k mile single cam for a fully rebuilt dual cam.i have the ecu and harness but do i need anything else?if you could tell me what else id need and why that would be a big help!if you direct me to a write up or wiring diagram thatd be sweet-THANKS!
haha well..two points..i was using it as an arrowand in math..the bigger number "eats" the smaller oneso no i had it correct in both fashionsdebbypak wrote:
nismobenzo wrote:i was using it as an arrow
debbypak wrote:... shouldnt it beKA24E->KA24DE? just sayingg...
Er thats what I was forgetting, you need the dohc tach, as it has a different signal and you wont read any rpm unless you have the proper tach. Speedo is exact same signal, thats just if you prefer the read out in 10-20-30mph type or 15-25-35mph type.nismobenzo wrote:
and thanks for the help..i wonder why some site said they had to swap out the speedobut i didnt know the ignition coils were different..man thats kind of a bummer since i just bought/installed a new one in my single cam a month ago lol and since i guess the power steering lines are different or something..why is a different pump/res necessary? i heard they are just in different locations but the single one will work fine..i think i saw that on zilvia..
actually, online people use > to say that one thing is better then anotherfor example NISSAN > hondas i wasn't referring to the actual engines..nismobenzo wrote:
