dickie »
https://forums.nicoclub.com/dickie-u32299.html
Thu Aug 09, 2007 7:41 am
for whatever reason you have decided to go to a SOHC engine in your DOHC-equipped car. okay...
the harness and ECU will need to be swapped for their SOHC counterparts. the tachometer will need to be SOHC too or it will not display correctly.
the transmission and components will mate to the SOHC block just fine.
PS hoses will need to be re-routed if you intend to use it.
there may be a few other things but that is what i can think of off of the top of my head.
note: from your comments it seems like you dont want to swap to SOHC but that is the only motor you can find? you are better off waiting for a DOHC because of the extra effort and cost required to convert the car.
