elwesso wrote:IMO its a losing situation to get ANOTHER Q and take a hit on the current one. I would personally bite the bullet and make your current one good.
What problems are you having?
It is actually the mass air not the TB like I said before. I get pretty hard bucking at idel in gear. I know of one bad injector and was told by the tech the rest are going out. I have started to hear the hum from the rear trunk area and I am getting a bit of a tick sound from the motor and I have changed the oil very recently.
I might actually have a line on another 94Q that is super cheap with 60k original miles! I even ran the carfax and it is real.
As annoying as it would be to move parts between the two I can get this other Q for a good amount less than all the repairs my current Q needs. that is sort of where I am stuck.
