float_6969 wrote:I ditched mine, and now I wish I had kept it. (with the SDS) No offense to SDS, but their idle valve doesn't raise my idle up hardly at all. The way that I would work it would be to run it like the factory does and tie it in with the fuel pump. Where my max cold idle now is only about 1100rpm, (less when the oil is really cold) you'd be more like 13-1500 rpm, and the idle would slowly drop, unlike the SDS where the idle just drops at the setpoint.
disclaimer: I'm not talking crap on SDS, as I LOVE my SDS system, but with the cold arse crappy KS winters, starting can be a little rough. It's always started for me, but it's always a little hesitant and seems to buck some. It's only a problem in the sub 40* range.
Don't feel bad man, mine does the same thing too. It cranks perfectly, fast idles, but when it gets close to its cut-off point, it acts a little stupid. But I can put up with that all day seeing the perfromance I get as well as the flexibility.
I am in awe with the way my car performs at 15psi of boost. It's just an amazingly wicked little ride with an amazingly wicked engine that is controlled by a superb engine management system (Nothing is perfect).
Dee
