240sx driftking »
https://forums.nicoclub.com/240sx-driftking-u52326.html
Tue Dec 19, 2006 11:22 am
Hi, I'm new to the forums. I have a 91 coupe that I am giving a 6,000$ makeover. First I paid nothing for the car(my uncle was getting rid of it). It is my second 240sx now. It has a 93 motor with 60k miles(freshly installed, pulled it and installed myself). I just ordered a turbo kit, n1 exhaust, test pipe cat, walbro fuel pump, silvia front end conversion, interior carpet, black leather bride seats, bride steering wheel, black dash(old one has a crack), drivers side door panel(old one is ripped), 4x 17" black rims with a polished lip w/ Avon Tech M550 A/S 205/45/r17 tires, jet black paint / white pearl, findanza flywheel & xtd 6 puck stage 3 clutch), UR underdrive pulley, obx helical diff, strut bars, sway bars, and the red and chrome taillights off ebay. I am keeping the body bone stock. I still got the 91 motor that I am going to build up for a more serious turbo app. I have a few things left to order and I need some help from someone that has experience with turbo dohc motors.
First the turbo is aT3T4 T04E TURBO CHARGER 3" inlet Diamenter /2"Outlet 0.58 5 Bolt Standard Hotside 0.63 A/R Cold 0.57 Cimpressor wheel trim 0.60 A/R Compressor 0.63 A/R Turbine 57 Trim Turbine Wheel: Exducer 2.48" / Mayor :2.89" Compressor Wheel : exducer :2.07" / Mayor 2.36" 35mm external wastegate with 7 and 10 psi springs27X25.5X5 INTERCOOLER with 2.5" piping3 inch exhaust with test pipewalbro fuel pumpI am going to order the jwt ecu after I get the injectorsI want to push 7 psi with this turbo on stock internals on a 93 motorWhat injector size should I go with for this setup?Is there anything else anyone would reccomend?Any suggestions would be appreciated. Thanks in advance.P.S. I'll take some pics tommorow and post them on here. I am doing all the work with a friend. The car is a little bit rough right now because I just got it 2 days ago. Give it about 4 weeks though.
