Jacko3 »
https://forums.nicoclub.com/jacko3-u85814.html
Mon Sep 22, 2008 7:04 am
Whiteclay:
I can tell you that the air temperature have some effect on performance--car performs better during fall than in summer--cooler air.
I also have everything you have in your car, though mine is a coupe with 19 inch wheels, and i can tell you that top end is slightly better than bottom end even before i hit 5500RPM since after installing test pipes. So, I hardly rev my car too high these days with the test pipes. But when i do, the torque above 5500 RPM is unbelievable.
This weekend on my way home from work, I was at a traffic light with a corvette, I think it was a red C-5 Corvette---I am not sure. When the light turned green, we went at it ( though I shouldn't have done so--but how can anyone pass up a challenge with a vette). I was surprised at how quickly I was able to beat the corvette in the beginning acceleration, but eventually he had me with his top end horspower. The vette had this strange sound when its RPM hit the top end. When i heard the sound, i knew he was gone.
We went at it again, at another light, and a similar thing occured---we were both neck and neck at first--I was just as quick at the low end, but as you know, a V-8 will smoke any G at the top end. One advantage the G had was impressive lateral stability, which the Corvette seemed to lack.
He was just fishtailing like heck, as a result of all that torque upon take off, going to the rear wheels. So, while he was busy steadying the car from fishtail, I was busy moving forward without any hinderances. I would say that the use of test pipes has almost eliminated any excessive torque that usually caused wheel spin under low RPMS. Again, It maybe that the vette driver was just not good at taking off---I don't know. But i don know its low end take off launch was not as good as that of the G. if the G had even 20 more horsepower, the vette would have been stopped in its track.
The G-35 is surprisingly capable for a car of that size if given the right set up and operating condition. I would say that anxiety and zeal could also cost a driver valuable time. I am not sure which mod is required to counter anxiety and zeal (j/k ).
In my opinion, there are three ways to make an N/A G-35 very capable and fast at a cheap rate.
1. The simplest and possibly cheapest is adding a cold air intake.
2. The next is adding a test pipe---this is also cheap too and it allowed for quicker revs---however, it may be that my spacer, Mrevv, and catback exhaust is making the test pipe more effective and functional than without these mods---i don't know yet.
3. The next is putting the G on a diet---reduce weight anywhere you can--the G is a sleeper monster once it sheds weight. I can say this, since after installing test pipes which does not weigh as much as the cats. Simply swithching to a Stillen catback exhaust reduced some weight as well. I am seriously considering removing the back seat of my G as the next weight reduction plan.
4. Use synthetic oil--allows pistons to rev faster.
I bet I have probably saved somewhere between 30 - 50 lbs since I added my mods to the G.
Modified by Jacko3 at 10:23 AM 9/22/2008
