jdpalo »
https://forums.nicoclub.com/jdpalo-u123339.html
Tue Dec 30, 2008 3:54 pm
Hi guys...I own a 1985 720 with a Z24, double coils, double plugs, etc. ...(I'm sure you're familiar with it)...early this past summer the IC unit in the distributor started acting up until it finally quit...it would start after several tries and, once it warmed up, it would start at the first try...it would try to die while running and backfires were the result (that's why I parked it)....work compromises definitely kept me away from getting it back on the road, until about a week ago... the timing chain and sprockets got replaced as did the water pump... got the new IC installed and tried to start it up, no way...no spark from the coils...did all the tests the Haynes manual describes for the coils, IC unit and peripherals, but it points back to the IC...got it replaced once more, still no spark...repaired the distributor (broken magnets under stator, play on the shaft) and will be putting it back together tomorrow...what if it still won't start? where should I look? What should I look for? Somebody mentioned a signal coming out of the ECM but I have no idea what to look for... anybody have any ideas? Immensly appreciated...
Jd
