thanks for the info manCams wrote:Rocking SSAC kit (pretty much the same thing as godspeed) for over 2 years, no problems, and many around here use similar setups with good results.
I'd recommend you get the S14 SR20DET kit if you can. Best fit mainly due to cold pipe shape.
Got mine for $250+sh back then, dunno whats the best deal right now tho.
Oh, and use the search, there is a pretty detailed thread with good info on most ebay items.
Could you post the link please?I went through the stickies but I couldn't find anything.float_6969 wrote:In the Stickies.
I just noticed you live in northern, va what part do you live in I live in annandale I mite be able to help you out with somethings lemme know if you need somethin email me at [email protected]S ll 3 k ll lD lD wrote:Nevermind I found it thanks alot
I live in Woodbridge your not to far...That would be cool man I will definately email you when im about to do my swap and install the parts on it...I will have everything by spring timefabio240 wrote:I just noticed you live in northern, va what part do you live in I live in annandale I mite be able to help you out with somethings lemme know if you need somethin email me at [email protected]
That is interesting please post the results when your done...Instead of godspeed im going to go with the ssac fmic kitbradt wrote:Had a shop install one (against my wishes, actually) and it seems "o.k".
I put o.k. in douchey internet quotes because while it seems to be a fairly stout piece (I stood on it to check mounting, and it didnt budge), the fins are spaced fairly far apart, and the bars seem a bit large. Once the car is back to running status, I am going to be installing temp probes to do some testing to find out how well it cools compared to some various other units.
I used to live in woodbridge and go there all the time send me your phone number ASAP!!!!!!!! [email protected]S ll 3 k ll lD lD wrote:
lol man I know you this is fred with the white s13 hatch that use to be at chevron with the zenki s14...I didn't realize that this was you because for your location it says "Maryland"fabio240 wrote:I used to live in woodbridge and go there all the time send me your phone number ASAP!!!!!!!! [email protected]
What?!...Someone stripped it?A tree fell on it?Talk about bad luck...What did they take?Good luck on getting another S13 man I wish you wellfabio240 wrote:I know I called Ron last nite and asked him your number and I was holy s*** I have another ca18det convert. But nah mine isnt done yet and plus I have to get another s13 because a tree fell on mine after I got it out of the impound lot after it was stripped....
I believe that they are in texas...S ll 3 k ll lD lD wrote:Thanks for letting me know man Im going to do research on the butterfly valve system I dont know anything about it...Do you know where jhot is located?I have never heard of them before
