God My Roommate is stupid!!!
MasterKen
Car: 1995 Nissan 240SX Base (Awaiting S14 SR20DET Blacktop Install)
Hey guys, ran myself into a little snag. I'm moments away from dropping my car and my SR off to get installed. Problem is my roommate was trying to do me a favor and examine the block, turbo and other misc. ****; which is good and all but when he took off the manifold and turbo he forgot to label where the oil return, water tube and.....basically those 3 lines that run from the turbo back to the block. I now have TAKA Steelbraided lines but i can't make heads or tails of the flippin' thing. Yes, i have searched and can't find anything. By the way, It's an S14 SR20DET VTC T28. Pics and advice are appreciated as well as flaming. Thank in advance!!!
otterman
If I remember right the water lines are the top two (not sure which is which). The oil feed line is the one closest to the bottom and the return line is that little tube almost on the back of the motor near the transmission.
zerothread?id=237738
FSM tells you whats what.
