onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Mon May 15, 2006 6:40 pm
Ok, so everything was working peachy. Replaced the starter on Saturday. Went up to the mountains for some late night cruising. Everything went well until I started up the car for the drive home - heard something weird, like if someone opened up the valve cap, threw a bolt or something in and let it loose in the engine.
Pulled over a couple miles down, checked all fluids, checked for leaks, damage. Everything was kosher, just the noise - which is a constant random clanking and rubbing from somewhere in the engine block, I couldn't narrow down the sound.
I drove it home anyway - about halfway down the freeway, I hit one of those uneven bumps in the road, and the sound disappears! Fine the rest of the way home...
Start up the car Monday morning, and EEEEEERRRRRRRRRRRR clanking rubbing metal sounds coming in louder than ever.
Just parked her on the driveway and took the other car for the day.
Came back tonight to peep through the oil cap, things "seem" normal - timing chain was still there, didn't look loose - don't have time to open up the valve cap or drop the oil pan to see what's wrong til at least this weekend.
Crank the car, and even when cranking you can hear a loud metal rubbing sound - so I stop and don't let the car start.
I'm guessing it can only be 1 of 3 things - something connected to the camshaft, crankshaft, timing chain... I'm just really at a lost as to where I should start. I have bigger car projects going on soon, and I just don't want to deal w/ an engine blowing up .
History:
January 2006 - put in a rebuilt head, new timing chain kit, new gaskets/head studs, 240z oil pump, new water pump, everything. Everything done to FSM spec as close as I could. Timing set to aproximately 15 degrees.
May 13th 2006 - put in replacement starter from Autozone to replace the bad one from autozone that lasted 2 years... everything ran fine, started up nice and fast until incident above.
Thanks in advance for any help/pointers.
