By "flagging" do you mean, stopping the line and taking care of it on the spot? My guess would be it's done this way keep the line from stopping.MinisterofDOOM wrote:Certainly a good quality control element. But if the computer's smart enough to label a bolt as improperly torqued, shouldn't it just flag it there? Why label it to be caught at the NEXT step?
General Motors in[i] Popular Mechanics[/i] wrote:Although quality control during the manufacturing process is the main goal of the new data-bolt RFID system, it is also proving to be a huge help in post-production troubleshooting. If a supplier notifies the factory of a bad batch of parts, it’s easy to zero in on the exact engines on which they were installed using the database of information saved from the bolts.
Perhaps part marketing for people, and part for any funny business at either the dealer or consumer level?PapaSmurf2k3 wrote:All those tools are transducerized and computer controlled already (and tied to the line so it will stop the line if something goes wrong).
It SOUNDS like the bolt itself doesn't have a mini strain gauge or something in it, and the tool itself is what writes the data to the bolt.
I'm struggling to see a true useful application for this.
Also, chances are if there is an issue, that means the bolt is already broken. If it's a threaded connection, that means the bolt is probably stuck inside something, which means that it may have to be drilled out, destroying the B-Chip... If it's a bolt/nut connection then that means it's probably busted in half and who knows if you could find it?PapaSmurf2k3 wrote:All those tools are transducerized and computer controlled already (and tied to the line so it will stop the line if something goes wrong).
