Hi all,
I was trying to fix a EVAP code and try to remove the evap valve to the canister and clean it. Here was the original article I was reading- p1456-solved-t560149.html
Unfortunately, I also shear the bolt off the evap valve from the canister. My question is - is it possible just to glue it back together with some RTV and tie it with some wires? Instead of buying new canister and valve. How much pressure there is at the EVAP valve and vapor canister?
Thought?
Ken
