Glue used for body panel?
iolo72
Car: 2016 Rogue SL
Hello,
I am in the process replacing the front LH fender. Once I removed the fender I noticed that a side of the fender is attached to the body using foam-like glue.
Does anyone know what this glue is and where I can get it? It's foamy but pretty resilient and tough to break loose.
I've attached a photo.
Thanks!
datechboss101
Car: 2016 Nissan Rogue SL -- RIP
2018 Nissan Kicks SR -- RIP
2019 Nissan Rogue SV w/ Prem. Pack
iolo72 wrote:
Mon Oct 23, 2017 11:50 am
Hello,
Thanks!
Not sure why you would remove that part of the vehicle unless you are repairing it from an accident or something. You should probably check Lowes' and Home Depot, as they would carry almost everything. If not, check Amazon and your local auto parts stores.
iolo72
Car: 2016 Rogue SL
Hey there, I am replacing it as the condition of the panel is not repairable. I checked out Home Depot/Lowes and couldn't find anything like that (and not much help from the employees).
I would like like to what the adhesive it so I know what to check on Amazon. I did find 3M Panel Bonding Adhesive but it's epoxy and seems like a hard glue when cured unlike the sponge/foamy characteristic of the above adhesive in the photo.
datechboss101
Did you checked your local auto parts store and harbor freight? Maybe they should have it or could tell you what it is called.
larry80
Car: 2017 Nissan Rogue SL Premium
SHAYE13
Car: '13 Nissan Rogue
T32 Nissan Rogue OMG LOL
Can you provide some more pics?
I used something similar before , and might have an idea what they used?
SHAYE13
^^ yeah btw it was 3m urethane foam
iolo72
Car: 2016 Rogue SL
I actually stumbled across the same page the larry80 linked this afternoon and after more research I think I found the product.
https://www.amazon.com/3M-04274-NVH-Dam ... B005IU2IPM
Does this look about right?
Return to “Rogue Forum”
