even if the engine is running super lean why would it cause the turbo to heat up when it is under virtually no load?J-Spec Tuner wrote:Well I *think* that most stock ECU's are programmed to run fairly lean at highway speed RPMS under light load for fuel milage purposes. Perhaps something with your fuel delivery setup is causing it to run even more lean and creating extra heat. Have you ever been on the dyno for wideband tuning?
just cuz there is no load doesnt mean that there isnt any friction going on in the turbo. im sure it was spinning which in turn creates heat. check the turbo lines, maybe somethings not right there.spider_slayer wrote:even if the engine is running super lean why would it cause the turbo to heat up when it is under virtually no load?
It could be rich or lean. It doesn't have to be lean to make it turn red...rich can also.92vert240 wrote:the turbo could spinn a million rpm's and it wouldnt get red hot if you were spinning it with cool air. Its your EGT. check your mixture/ fuel system. Get on a dyno and set up your mixture. Ive seen this before on non turbo aplications. headers glowing. Way too Lean.
I've seen headers glow while drifting/playing in a parking lot at low speeds for a while. This was also on a really cold night, the colder the temp the brighter they'll glow. But just cruising down the highway definately sounds like advanced timing, or lean mixture............... be careful.spider_slayer wrote:the only time i've ever seen headers glow was when we have the timing advanced.
the tps does not measure airflow, merely the engine uses it as a cross reference point for the total engine load. the mass airflow sensor measures actual airflow (who would of thunk that haha) the tps should have 3 wires if im not mistaken. a supply voltage, a ground and a signal voltage. make sure you are checking the signal voltage and not the supply, supply will be constant, signal will change as you move the tps. if the signal does not change it is a faulty tps, if the signal voltage is not within spec it is a problem within your wiring harnessTheSparo wrote:ok, let me know if this makes sense, i figured since my timing is correct, and i am getting ~41psi of fuel, that the only plausible cause would possibly be my TPS sensor... now i know most of you are like why would that matter...well... i checked the voltage on it, and it was low (like .14 volts or so) and no matter how much i turned it, the voltage wouldn't change... which it should change, and is suppose to be at .47 volts if i am not mistaken... so anyway, back to my point...i think that maybe my TPS is bad, causing the ECU to read less air than is actually being pulled in, which in turn creates an overly lean condition, which in turn heats up my turbo, which in turn pisses me off because there is no way to possitively know because i don't have a spare one and new ones cost $130 or so...
