illdrifter »
https://forums.nicoclub.com/illdrifter-u178918.html
Wed Feb 23, 2011 6:55 pm
I have a 90 auto sohc which i converted to a dohc 5 speed . I had a dohc motor that ran just fine in it until it spud a rod bearing . I got another dohc motor n put it in . i have prob set the timeing 20+ times with it . The only way it will run is with the distribtor one tooth advanced and the distribitor fully advanced . once it actually cranks after paddeling the gas and multable turnovers there are no mechanical noises or rattels but it hesatates terribaly and the header will start glowing red in the matter of a min or 2 . Also i have done a fully emmisions removeal 4 into one header with a 2 1/2 strait exhaust . Which all worked fine with the last motor . Any help will be greatly appreceated . Thanks again
