glow gauges
superuber
Where can I get these?
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
I have seen plentiful LED gauge glow kits in Japan but have never seen them installed. They aren't VERY pricey. Honestly your better off getting an impul gauge cluster which have glowing gauges and extra lighting and such
superuber
can you get me one for my 95? I didn't know they existed.
BCC93QT
1995 Infiniti Q45
They measure in kilometers rather than miles... You would have to swap your MPH piece out from your car. Let me see if I have a pic handy to show you. I haven't seen any FS in japan for a month or so now but they pop up
superuber
Yes, I would love to see a pic of one. I'm very interested.
BCC93QT
1995 Infiniti Q45
this is just a cluster with the "impul" speedo put in. There is an ACTUAL "impul" cluster with light up jewels and LED blue background
superuber
very nice! When can you get one? I would love to see a night pick. The message center is switched. Will it still work ok?
BCC93QT
1995 Infiniti Q45
Would have to cross wire it.... as far as wiring the gears into the cluster would be grand ole job as well. I have a fairly large book for wireing for the president but of course its in japanese. The pictures look doable
BCC93QT
1995 Infiniti Q45
Can you read japanese?
BCC93QT
1995 Infiniti Q45
j.hardstyle
Car: 1992 Infiniti Q45 (G50)
140,000 Miles
s***, i would want that just for the gear select in the middle of the cluster.
BCC93QT
1995 Infiniti Q45
I can get stock JDM ones fairly inexpensive but the surgery involved is time consuming and at best difficuly. If you cant read japanese you have to swap the display unit out... KMH to MPH... Odomoter is KM not miles.... Removing cover to start.... BUT im sure it can be done. Largest concern would be wiring it to the shifter
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Its not worth putting in a shift indicator....I used to think it was nice till I saw every car has one.
BCC93QT
1995 Infiniti Q45
Hell it aint worth keeping a G50 on the road but thats what were doing. Right?
Infinitiguy19
True but that shift indicator project is a hell of a project. I say that because the JDM shifter faces the other way (1-2). Wiring it to the neutral safety switch is easy compared to switching around 1 and 2 on the indicator.
