Glovebox Voltage question
TDot
Car: 2008 M35X, Lakeshore Slate/Tan
Planning on doing something. Does anyone happen to know what the voltage is going to the light in the glovebox? Don't really want to bother breaking out the VOM and splicing the wire to find out its not the voltage I need? Or which fsm is the info in?
SmoovC
Car: '06 Infiniti M45 Premium, Brakemotive, H-Techs, KYB's, USA-Spec PA15-INFI w/ BT streaming, Kuda cell mount, Magnaflow exhaust. (CAR SOLD)
Current: 2012 Infiniti M56S, Harbour Blue, 4 pc Aero Kit
If it is a 12 volt light bulb, it would be 12 volts, right? Or are you trying to figure out how much current?
EniGmA1987
Car: '06 Infiniti M35 Sport
Pretty sure just about everything is 12V stuff. You will have to find where the wires go and what fuse they run through though because if you put too much draw then you will blow the fuse and possibly melt the wiring since they are small wires and not rated for much.
svard75
Car: 06 M35x
Glove box lamp : 12 V - 1.4 W Quoted from Alldata
TDot
I thought there should be 12. The thing I was hooking up wasn't triggering so I thought there was low voltage, but it turns out the teeth on my coupler didn't penetrate the wire jacket. All good now, thanks.
