glove box removal
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
ex35tdt
Anybody removed glove box? can you tell me how to remove the pin on the left?
NJ_EX35
Car: Infiniti EX35 Journey w/Navi
Are you referring to the screw that is in a pretty tight space? if so you will need a very small screw driver to get in there. I just removed the glove box with the small screw driver to replace the filter and did it in less than 10 minutes. Hope this helps, the link below has the screw driver I used to get that last screw out.
http://www.sears.com/shc/s/p_10153_1260 ... ockType=G6
ex35tdt
Thanks!
I think that can only be done with a very small hand :)
I'm afraid if I can get it out, I cannot get it screw back in.
NJ_EX35
It was a tight squeeze, but if you set the screw driver in first and re-position your hand to unscrew you should be ok. My hands are pretty big and I had no problems. If not I suggest a ratchet wrench with a flexible neck that will let you get in there.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
