DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Fri Jan 17, 2003 3:38 am
Very common problem. The stupid little plastic lever breaks off everytime. Very difficult to fix without destroying the 2 lower hinges, as the latch on top is almost bulletproof. My advice is to find a replacement glove box first from a wrecking yard, and then go in and remove the hinge pins below, with your head on the floor, and your feet on the passenger headrest. Once you get it out you will need to swap the lock mechanism and reinstall the box. 4 screws and the little retaining strings. What color glove box do you need?
