elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Dec 31, 2005 10:47 am
You read the thing on Q45.org?????
theyre all the same... It applies..... sorta
Remove the lower plastic thing below the glove box.. Once you remove that, there are 4 screws (2 on each side) that you remove, plus the 2 up top. Use a 10mm wrench...... After that, take out the darlington resistor and then clean away!
