krash133 wrote:The early Boxsters 97-01 had a vinyl window that folded in the middle and would wear out with age quickly. The aftermarket retrofit glass window kit has a 3/4 size of the original vinyl piece now in glass that folds at the edge of the glass, which is enough to get it to slow away like the original. Might or might not work on the 240, but it could be worth a shot.
One more way to skin a cat!
WOA WOA WOA WOA! It's another krash! Let it be known: Refer to him with the numbers at the end, krash133. I still get to be called krash, I was here first hehehehe jk btw any history behind that name dude? I'm just excited because anywhere I try to sign up it tells me the "krash" is already taken and I never see the "krash" so I have to use numbers
I dont really like it, but super props to you for doing it! that must have been hard! I would have made it a two peice glass back window if I did it. Its a really good install, Do you work with this kinda stuff alot? I'd say stock unless youre going to do 2-peice glass window.
