C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Tue Jun 05, 2007 12:34 pm
Most glass mount antennas, whether amplified or not can be pretty iffy simply due to their design. A good radio antenna is usually about 18 inches long as the FM frequencies waves are about that long. Glass not only can interfere with some of the signal, but can limit how large the antenna can be. When I had my G35 coupe, the antenna was mounted in the rear glass from the factory. It had some difficulty picking up local channels that are usually quite easy to receive via a more typical mast type of antenna.
