GL4 and GL5, what gives??? Transmission fluid question...
lbrowne
Ok so I read on here everywhere to not get GL-5 gear oil for the 240sx transmission, that it eats the synchros. I know many on here put Redline gear oil in their transmission and the general accepted weight is 75/90 for most gear oils used.
Well...
I've been to 2 shops and none of them carry GL-4. The coveted Redline gear oil lists as exceeding GL-5 requirements. So what gives??
I found 2 brands of gear oil, that listed as meeting or exceeding both GL-4 and GL-5 on the label. Nothing that says just GL-4.
So man up fellas and tell me what you use because I'm not going on a wild goose chase for oil that isn't out there. (this elusive GL-4 only oil)
edit: you guys must be using MT90 from what I can now tell, I was looking at the wrong redline product!
Modified by lbrowne at 12:48 PM 7/27/2007
lbrowne
I found a local supplier of Redline thank god. Those other shops had nothing that I could use. I had the meets GL4/GL5 in my hand and decided to put it back until I verified everything on here.
Excuse my panic, the heat is getting to me! lol
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Redline is hard for me to come by as well so I just run Royal Purple.
Moto Man
Car: 93 240SX
You want oil that meets the GL-4 requirements. If it meets the GL-5 requirements as well, that's ok.
battleroyale
the big worry about the gL-4 and gL-5 debate is that some gL-5's aren't yellow metal friendly, and they can wear out your brass syncros
I emailed valvoline and some other oil manufactures before to clear this up and they said that it would be fine to use their gL-5 formula with yellow metals
