sjbsuperman1425 »
https://forums.nicoclub.com/sjbsuperman1425-u80456.html
Wed Jul 16, 2014 5:03 am
So Ryan, I e-mailed Gizzmo yesterday before leaving work and this is their response I received this morning before coming into work:
""Hi Zak,
We have not had and direct experience with this particular concern, however I can provide our own prospective on the situation. It just so happens that my background is in thermal engineering and engine design. I just want to make sure I understand the question and engine layout. I’ll attempt to explain the concept without going into the boring details though.
My assumption is the thought is as follows: Now that the manifold isn’t soaking and forcing the metal in the runners to the same temperature that the air in one cylinder may be warmer (or cooler) as the port on the head is cooler in that location.
This should not be a concern due to the velocity of the air in the runners. The manifold has a large mass of air in it at a (relatively) low velocity. The runners on the other hand always have a charge of air moving either towards the valve when open, or “rebounding” from the valve after it’s shut and traveling back towards the plenum/manifold. The point here is that the air in the runner is never really stagnate. Heat transfer is a partly time dependent function (depending on the mode of course). Since the particle of air never spends a significant amount of time in the area of heat differential the heat transfer is relatively insignificant.
The idea of the thermal gasket is to prevent heat transfer to or from the manifold, promoting cooler temps in the manifold. The manifold overall will still seek to reach a steady state temperature, the same with the air in the manifold. There just isn’t enough time and surface area in the runner and local area to heat the air in that local location. As the intake manifold is mostly isolated from the effects of the head and the engine it will reach a fairly even and steady temperature driven mostly by the under hood temperatures and temperature of the incoming intake air.
It take a surprising complex design to create a significant impact on air temperature in a moving air stream (think of an intercooler design, or of radiator design for example).
Of course the chance for a little variation always exists, and no system can truly be isolated from the surroundings. From a basic concept though I would say that there is no significant concern for a significant heat imbalance across the cylinders.
Let me know if you would like to discuss this topic further or if there are other concerns. Hopefully this has been the helpful answer you were looking for.
Thanks and best regards,
Brian Barnhill""
