Step one was to trace out the shape of the harness on my work surface. I took my sharpie and traced out the outline as well as where clips went so I would have a good approximation of where things would go back together. I've got no good pictures of that step, but I wasn't concerned with documenting that kind of stuff. I did take plenty of pictures of what the harness looked like before I sliced it all to hell.
After I removed the looming, I started looking at what circuits I should remove. I removed everything associated with the pop ups, all the wiring from the SMJ to the relay boxes, including the relay bases. I left one circuit in place to continue running my fog light setup. I also removed all the A/C pieces, and adapted the fan relay to run my e-fan. I also hijacked the circuit for the neutral switch and am using it for a future oil pressure sending unit for when I put in an aftermarket unit. All I'll have to do is access the SMJ on the interior side and add a wire in there. I also removed the circuits for the 4th and 5th gear switches. Never used them in the beginning anyways. I also pulled the clutch interlock relay and the clutch switch. I've been running for years without one, and the cannucks don't use it, so I figure it's one less expensive thing that can break.
Things I added were an ignition coil relay, in the spot in the relay box for the ignition coil relay. I've gotta scavenge a larger gauge connector from my harness in the car before I finish that bit up. I looked at how the factory does its fog light setup since there's no documentation on it, and it's stupid simple. They run a wire from the low beam to a relay solenoid, then they run that to the switch. When you turn the switch on, it grounds the circuit and completes the fog lights' supply circuit. I adapted that to run off the low beams and run back to my pop up switch.
All in all, once I tallied up the amount of crap I removed, I came out to 24 circuits removed and 4 relays plus a handful of plugs.
All the wires I removed.
The harness cleaned and reassembled! I still need to button a few things up, but I need to scavenge plugs from my car first.
I thought about removing this box completely, but I didn't have enough room in the other box to do that
I need to snag a green or blue relay from my car to put in the fan relay spot.
