Giving a little back: Basic Kill Switch Diagram
PhopsonNY
Car: 1989 Nissan 240SX
Thought someone might be able to use my diagram
cheers
Chris28
Car: 92 s13 KA-T
All you have to do is put an inline switch in one of the wires coming out the ecu. It's a low amperage wire so it's not dangerous to run underneath carpet with a small gauge wire.
Good diagram, but there is a much simpler solution.
PhopsonNY
The point of a proper kill switch is to remove all power from the system in case of emergency... short, fuel spill, errant ecu behavior, dieseling etc...
That is why the kill is put on the positive leg not the negative.
Modified by PhopsonNY at 10:23 AM 1/12/2010
Chris28
Car: 92 s13 KA-T
Ah, so it's a safety kill switch. That makes more sense. I was thinking it was merely an anti-theft device.
In that case, great contribution.
sommmatt
I like.
RedSubdivisions
Car: 1989 BMW 325i, 2002 BMW 330i
What about this Killswitch?
PhopsonNY
would definetly cause emergency shutdown...
Steve Lloyd
the alternator needs to be interrupted for it to be a safety switch.
PhopsonNY
disconnected from what?
spooled240
Car: kouki s14
all you would have to do is install a battery shut-off switch, i had to install one to race when I relocated my battery to the trunk. Any sort of switch in-line with the battery cables would have to be a heavy-duty high-amp switch tho
...anti-theft switch, well that's a different story
PhopsonNY
Good points... but
In some cases, the alternator can keep car doing in absence of the battery.
I also prefer a block between battery and alternator even though switches can be high current too.
This is for emergency shut off as stated above.
spooled240 wrote:all you would have to do is install a battery shut-off switch, i had to install one to race when I relocated my battery to the trunk. Any sort of switch in-line with the battery cables would have to be a heavy-duty high-amp switch tho
