Girlfriend's 1999 Altima Sedan.. key won't turn
General discussion area for the L30-chassis Altima
zinch
Car: '93 RX-7 , in the market for a 89-94 fastback
Maybe I'm completely blind when searching, but I missed finding a solution for this.. My girlfriend drives a 1999 Nissan Altima Sedan, automatic.. We went to get groceries and when we got back to the car and tried to start it, the key wouldn't physically turn in the ignition.. I can't move the gear shift out of park and into 1st or neutral.. The wheel seems to be locked as well.. Any suggestions would be greatly appreciated.. Thank you..
-Mike
sterlkreed
Had the same thing happen with my 98 altima. I had two keys neither worked. I called a locksmith and he used the old keys to build up a new key. The keys had worn down so much that they didn't work. If you have a spare key that has been rarely used it might work. Apparently this is fairly common with altima keys
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Try applying a little turn of the key while you try to pull it out slightly. A worn key will cause all kinds of grief.
Return to “2nd Generation Altima Sedan (1998-2001)”
