Giggle Juice
SnakeEyedTranny
Car: 2001 Pontiac Trans Am
I didnt see any other threads on the topic, but does anyone know what the stock block is good for in terms of nitrous? What size shot is safe to run?
nosduj
Car: 90 300zx
I run 100 on a reg basis, and my junk has 226,000 miles on it. I did the headgaskets a few years back, but other than that no biggie. I dont think that I would run more than that on a stock block.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Welcome to Nico!it's kinda a tricky question, are wel talking about a dry shot or wet? on an N/A car or a TT, are we talking about a single fogger, spray bar or muitl point? what kind f controller? switch activated? puch button? electronic? are you going to change you're base timing? there are a lot of factors to considder, thats why NO2 is considdered a bit of a black art, the basic rule of thumb is that you can add up to 50% of you're stock horsepower with a basic kit and some simple saftey precautions, if however you get greedy you will blow up your motor, I should know I've done it
basic suggestion, I'd suggest shopping for a kit intended for your car, hopefully electronic controlled, and it will have guidelines and suggested jetting, you can even call the manufacturer
perana
Yes you are absolutely correct.I used a 150 hp system on a high boost motor and the effects where detremental.I then changed the foggers and used it on my daily driven N/A,but i must warn any one using over 50 hp on a N/A clutch to change to something more high peformance.Allso don'tl launch your car off the rev limiter with the gas.Other than that and ofcourse a controller.Its good fun on a N/a.
