Gid'day QX4 blower conundrum
DocHudson77
Car: 03 QX4
Ok ...been through a ton of threads already , haven't found anything. blower motor on an 03 QX4 works intermittently....30 -120 seconds after start. then quits. ll fuses checked and OK , blower motor works, air filters clean......checked regulator all good....so HELP...don't want to drop 2oo+ on a regulator is that isn't the problem
thanks DOC
darylzero
I assume you read through this thread? blower-motor-problem-t289709.html
That part may have been $200 years ago now on Amazon it's $112. https://www.amazon.com/Genuine-Nissan-2 ... B00BFE5NN4
Many people in that thread said it fixed their problem. Why not order it and try it, if it doesn't work return it.
DocHudson77
Car: 03 QX4
Yes I had read through that thread. Pricing I had was Canadian from the dealer....and the dealer was lowest at $236 and change and up as high as 300+
My worry is the intermittent nature of the problem if the resistor is cooked would it not give full blast or no blast at all?
I appreciate the link to the Amazon site for the cheapest I have found the part ! I will give it a shot and update.
thanks !
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Topic moved to Pathfinder Forum / Infiniti QX4 Forum
attofarad
Car: 2001 QX4
Access the blower motor. Hook up 12V/Gnd directly to the motor. It should run on high and keep going. If it stops, as you are currently finding, then replace it. Or maybe you already did that.
https://www.amazon.com/gp/product/B000I ... UTF8&psc=1
