newdude1 wrote:whats the COP?
And Ill find out what fuel pressure they normal use but I was under the impression its stock.
And Ill also check the CTS sensor.
But the weird thing is, is that the car ran perfect before the tune, injectors, maf, and turbo. And the maf checked out fine and the injectors did too. This is the reason I think its in the ecu. I called JWT and they said it cost 25 bucks for them to check it so Im going to do that and see what happens.
It will be cheaper and quicker to find out what they have fuel pressure set at for their tunes, and to check yours than to send your ecu off. If you find low pressure then there will be no need to send your ecu off just yet. You could have leaky lines, dieing pump, or the pump might not be getting a full 12.5V throughout the rpm range, vac leak at the fpr, dead fpr. You will narrow down a lot of things by checking it. And just because the shop "said" the fuel pump was good doesnt mean they are right, or if they even checked it.
