I'll elaborate, a high pressure pump (150+ psi) is needed to create such a fine mist to be used as water injection, stock one is not even close.Structure240sx wrote:i think the problem is that the pump isnt strong enough. people have used it as an intercooler sprayer
wtf 300 to 400 psi LMAO, thats wrong ,you can do it with the stock pump, and it really sprays good , so, wat about the fuel injectors , they only get 30 to 50 psi of fuel and that sprays good! i think you have to rethink that oneCheckered-Member wrote:I'll elaborate, a high pressure pump (300-400psi) is needed to create such a fine mist to be used as water injection, stock one is not even close.
All you need is a high pressure pump, high pressure lines, a couple of adapters and a nozzle and you can use the reservoir as the source of water
a quick search and most kits come with 150+ psi pumps, there is no way the stock one can produce that much I swear I saw water injection kis with a 300psi pump214kka-et240sx wrote:wtf 300 to 400 psi LMAO, thats wrong ,you can do it with the stock pump, and it really sprays good , so, wat about the fuel injectors , they only get 30 to 50 psi of fuel and that sprays good! i think you have to rethink that one
Most common is 50/50 why? Because its easiest to measurefabio420 wrote:What % should the mixture of denatured alcohol and water be? Is it different for different amounts of boost/horsepower?
