Ghetto Blaster Problems (RB25DET).
Bluefire
I would check your timing as well as doing a boost pressure test to make sure there are no leaks
-Bluefire
Shocker
Car: 89 240sxHB rb26/30
silviasgp06 wrote:ok ill be waiting on a reply then, but ill double check my voltage today to see where it stands.
.omgsky: yes you need a regulator unless your using a r33gts-t pump, buts its good to have anyways. but check yours pump voltage
Modified by silviasgp06 at 6:56 AM 3/24/2008
Ok I checked out my wiring. On the 4 pin bosch relay I've got pin 86 hooked up to my fuel pump wire out of the ECU, pin 85 is hooked up to my ign switch, pin 87 is fused through a 10 gauge wire straight to my battery, pin 30 is a 10 gauge wire straight to my fuel pump.
I'm getting 14.5 volts to the fuel pump this way, granted I'm idling at 1800-2000 rpm.. (yeah I need a tune Saturday ) But when e-fans are on it drops to 14.2-3 volts. Quest alternator FTW!
hope this helps.
omgsky
Car: S13
Ran the codes on the ecu. Got a knock sensor code. Found an unplugged knock sensor. Solved the problem in first, but in second I have the same fuel (cut?) starvatian issue in second!
Shocker
omgsky wrote:Ran the codes on the ecu. Got a knock sensor code. Found an unplugged knock sensor. Solved the problem in first, but in second I have the same fuel (cut?) starvatian issue in second!
wonder if they are picking up knock... your FP is 43 with vac on right?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
And if one was unplugged, did you check the other one as well?
