Great info man. I've been looking for an avg price on that kinda job for awhile. Time to make an appt with a transmission shop Vroom - Chirp - Vroombeancooker wrote:It's a VB mod (valve body modification). You will most likely want to go to a transmission shop to have it done. They should charge around $400. for the VB mod and a transmission cooler installed and out the door. I am pretty mechanically inclined, but don't think that I would attemp this one at home.
I'll look around for more info on the GAB, but they will all be about the same. You are pretty much opening up the airbox. You could cut the top part of the box out, on the dirty air side. Then you would still have the clips holding in the air filter, but getting better airflow.
Ehh... One quick question. Can the VB mod be done at "any" transmission shop thats local, or do you have to find a shop thats speciallized in it?beancooker wrote:It's a VB mod (valve body modification). You will most likely want to go to a transmission shop to have it done. They should charge around $400. for the VB mod and a transmission cooler installed and out the door. I am pretty mechanically inclined, but don't think that I would attemp this one at home.
DjNikos wrote:Ehh... One quick question. Can the VB mod be done at "any" transmission shop thats local, or do you have to find a shop thats speciallized in it?
