getting white smoke!
ray666
Car: '92 240 sr powered tuned with a neo
okay i don't know what the deal is with it but, the car dumps gas like a mutha at start up. once it warms up the a/f kinda stabilizes but smokes like crazy! i check the obvious oil/ coolant mix but didn't find anything. does this sound familiar to anyone? oh yeah if i let it idle for a while it will try to die and i see the oil light flicker, very weird. i've only seen it do that 2 or 3 times over 2 week period that this started happenning
Justin35ll
Car: s13 coupe sr20det
Check and make sure your not leaking fuel past the injectors orings.Check and make sure the injectors are working properly
shift_SRDETuser
Car: 1996 Nissan 240SX SE
white smoke is usually a coolant issue. You might see a little white smoke while the car goes to normal operating temps but after it gets there you should see none. I would check among other things your head gasket or even thermostat to make sure it is opening properly. You could also check your water pump -- could be bad coolant flow through motor.
Justin35ll
coolant will deff give off white smoke, but excess fuel will too. and a lot of it. I know from experience.
And since he stated the engine was stumbling and running rich that could be the problem.Check for both, but I've had a problem of running rich/missfiring/ and a lot of white smoke coming from the exhaust and it happened to be a 4th injector oring that was leaking.
ray666
cool i'll have to check all of those. i did find that i have lost some coolant too i popped the cap to take a look and i had to add almost a quart?!i might have multiple issues going on at the same time. crap...
ray666
i took the spark plugs off to inspect and found the second from the front has what looks like oil on the threads.
ray666
well found out i have a blown head gasket. hopefully not a cracked head. sr's aren't notorious for that are they?
