Ok, got the dreaded knock sensor code on my 1994 Q45 (271k). Was running like a top until this happened.
So I'm going to have my mechanic:
replace both knock sensors
replace knock sensor harness
replace plenum gasket?
check/replace any injectors needing it
check/replace any hoses needing it
What am I missing?
He's a very experienced guy (professional), albeit on Toyota/Lexus (and now Audi). Tells me that I can expect different ohm readings on warm and cold injectors so he is not so sure about replacing injectors based on cold ohm readings.
Any feedback on this Q45tech? I remember reading your post on keeping a Q going until nearly 400k miles and that is my ambition, so I've been rigorous on the maintenance on this girl.
I noticed the power was down the last few months and put it down to the pistons/rings getting a bit sloppy but now I wonder if it was the timing gradually retarding (?) as the knock sensor went south.
I don't want to go under the plenum ever again so wondering what else might fail under there.
