Getting to Vac Lines
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Aven
Car: 84 720 Kingcab
Thought I'd take another stab at the vac lines. I need to replace the ones that run in front of the engine. How do you get to them on the carb side? My hands aren't that big, but I can just barely touch the top one when it meets the tubing. It seems like everything is in the way.
captainzeros
Car:
1981 Datsun 720 Longbed
1973 Datsun 240Z
You can take off the air cleaner to get at the carb, there are two bolts into the valve cover and one in the center above the carb.
PEZi
yep... just gotta get the air cleaner out of the way and have at it
Aven
Car: 84 720 Kingcab
Yeah, I have it off. But I still can't reach where the lines come across the front of the engine. They connect between a radiator hose, the alternator, and the master cylinder(?). I can't get my hand in between them all to actually reach where the hose and the tube connect, heck I can barely see them with a flashlight. I don't know if it makes a difference or not, but its a California truck.
PEZi
i don't remember mine really being an issue there.... got a pic for reference?
Aven
Car: 84 720 Kingcab
I'll try to get one tonight, if there is enough light when I get home.
Aven
Car: 84 720 Kingcab
The lighting isn't great, but hopefully its enough.
http://www.bluemelon.com/aven21/84nissan720
PEZi
ah... i see the issue now
the reason mine were so easy to get to was because i have the belt and pulley as well as the power steering pump all removed... i'm not sure i really have any suggestions as to how to get to them for you without removing the stuff and getting it out of the way
Aven
Car: 84 720 Kingcab
Thanks.
Crap.
PEZi
to be honest... if you have a little time on your hands... moving that stuff out of the way and reinstalling it after isn't the worst thing in the world
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
They have to be removed and reinstalled when you're finished.
Aven
Car: 84 720 Kingcab
It's all do-able, I was just hoping that there was one thing I could loosen and move to get it done.
Thanks.
bracktheron720
Car: 1984 720 with 1980 datsun front end,1972 yamaha cs3
i did my vac line delete as soon as i got my truck of the three that ran in front of the motor i pulled the two that went to the vacuum canister and left only the cavuum advance....ill put i pic of it up as soon as i can!!im pretty sure i just grabbed the suckers and pulled them off...but replaicing them im not sure i just removed mine!!
moredunes720
Car: 1985 nissan 720 4x4
I made the mistake of connecting the wrong lines on mine, but you can get at it from underneath, preferably with the truck up on ramps. I had to have a friend shine a flashlight in there, and it was still a tight squeeze. The bracket and assembly for the power steering pump were really hard to maneuver around. Goood luck man, I had some bloody knuckles after that one lol
Aven
Car: 84 720 Kingcab
Thanks. I'll take a look this weekend.
Aven
Car: 84 720 Kingcab
I was able to replace those hoses today. Ended up taking out the battery, loosening the belt and taking out the power steering pump bracket. That gave me room to get my hands in there and I could see what I was doing. Much easier than I thought it would be.
As an added bonus, I cleaned up the ground mounted on the bracket bolt. It really needed it.
Tomorrow I'll finish with the ball joints.
Modified by Aven at 11:34 PM 3/13/2010
PEZi
good stuff man!
Return to “Datsun 720”
