Getting to 300HP w/ SR20det
dream240sx2
Car: 240sx
Got a S13 SR20det setting on engine stand, while I've got it out I want to do all that I can to make the performance I want , which is achieving 300hp at the wheels. Here's what's going to be done, walbro fuel pump upgrade, 550 injects, 28 potatoe turbo, front mount intercooler, and electronic boost control. Anything I should do to the engine (shave the heads or pistons/ replace), cam shaft upgrade? Or should the stock internals be able to push the 300 w/ just upgrading fuel and turbo? Any input is apprecaited! Thanks!
s13sr20chris
well, that depends on your budget. you could make 300whp just like that with the right tuning. if you can afford it i would reccomend a rocker arm stopper, some mild cams, and not much else. if you want to do more you can always buy a gasket set(~$300), some bearings(after you figure out the grade), some rings, etc. that stuff starts adding up quick though when you could do just fine on the stock setup.
dustyk
Im assuming that you have an aftermarket turbo outlet and dowpipe already? You are definitely going to need a Z32 MAF and some form of engine management to control your larger injectors, but Im assuming you already have that taken care of. Other than for you If you have the money get some mild cams to help the turbo spool up and a metal head gasket to be on the safe side.
getnrowdy23
Car: '95 sr20det 240sx se/2004 suzuki sv650s
yeah, z32 maf and z32 fuel filter (does do a whole lot but makes me feel better for 15 bucks) downpipe and exhaust 3" preferably. descent/good bov so no boost leaks.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
You can hit 300 without spending money on an expensive turbo like the "potato". There are many T25 reworks that can net 325+.
robbbby
I hope you did a compression check on the motor. That would tell you if you should be considering rebuilding the bottom end. Especially since you have it out and on an engine stand. Trust me, it's ****ty to do things twice.
GTS4-R
Car: my feet
ha twice.....ill be ripping my out for the 3rd time soon.....i built the head last year and never touched the bottom end.....(def shoulda)...now that i want more power its gotta happen.....the goal will be 550rwhp with a GT35R
sgpnismo
http://www.nicoclub.com/zerothread?id=92457
i made 307hp and 300ft/lbs of torque with similar mods to what you have plus i have a z32 maf, jwt ecu and a forcedperforce big28 turbo. I was running 17psi on 100octane.
XdeathstarX180SX
Car: part s13 and part s14
i hit 303hp 243lb torque whp on 91 ca piss gas on 15.5 psi kouki s14 motor with a gtrs stock head and intake manifold front mount z32 mafs 550cc inj 3inch out
close to 300 hope it helps you out
im trying to hit 350 on 91oct and 400 on race with a stock head with future mods 740cc inj greddy intk manifold rocker arm stopper
Morph
Car: 91 Sr Powered Coupe
Shouldnt u be using 93
hpmachine
Car: '05 EVO8 + '95 240sx
i believe 91 is the highest octane available at the pumps in cali...
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
old *** thread.
ILikeMy240sx
Car: SR Power
holy crap... how did you find this fcuking thread?
Hijacker
Car: '92 240sx Convertible
'94 F-150
only post relavent information in this thread please.
i don't want this thread bumped from useless stuff
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
im gonna get the FPBig28
for 800 bucks you cant beat it.....quick spool and people are making 370whp with it
