DanDrath »
https://forums.nicoclub.com/dandrath-u133577.html
Fri May 21, 2010 7:45 am
Alright so now i got the car to start after putting a working cas into it. The car will only start with the cas turned all the way to the right. It stays idleing at about 700 rpms. If i give it any gas the car will stall. Now i know all my electrical is correct because a few days ago the car ran for about 2 minutes perfectly. than cut out when i turned the cas. I re timed the engine again to make sure it was correct. I am 99.9999 percent sure its correct. I must have 10 timing threads book marked. What else could be causing this. I am so confused lol
