Getting studs off old water pump?
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
like the title says, im trying to get the studs off my old water pump to put them on my new ... how do i get those f*****s off? any tips? suggestions? tricks? :wtf2: ive searched and found nothing on it
or anyone know what kind/ size of stud i can go get at any local hardware store
thanks for any help/ input in advance..
Hijacker
Car: '92 240sx Convertible
'94 F-150
Take two of the nuts and thread them on. Then jam the lower nut to the upper nut. They should hold and you can spin the nut out.
badbob2121
i think im overthinking this... i still cant get it
omgshawn
Car: S13, EG hatch
Step 1, look at stud. Step 2, screw on a nut, upside down. Step 3, screw on another nut, this time facing the correct way. Step 4, grab a wrench. Step 5, put wrench on lower nut, then simply unscrew it.
badbob2121
how would u put the nut upside down? my nuts are the same and have no up and down side to them>>?
Hijacker
'94 F-150
Just thread them on. Up down left or right
badbob2121
ya i just did what your saying a one stud broke?
anyone the size of the stud so i can go buy new?
motoman399
Car: 98' wrecked (RHD coming soon) 240
the size is 6X1.0 for a 10mm head bolt/nut
ill do my best to explain what they tried.
if you have nuts with a flange on the bottom, then that is where the upside down part comes into play. so take a nut that threads onto the stud, thread it on most of the way. then take another nut of the same thread and put it on just like you would normally. tighten the two nuts together (the bottom one loosen and the top one tighten) then take your wrenches off and use only one wrench on the bottom nut only and loosen. the two nuts "jammed" together should remove the stud.
snap on sells stud extractors which are freakin bad to the bone. but they are expensive.
if you break more studs i have some ill send you for free. but you can go to nissan/parts store/hardware store if you need to.
hope you get it from that
motoman399
found this for you
[youtube]http://www.youtube.com/watch?v=66ATKL4G04M[/youtube]
badbob2121
thank you, thats what i was looking for exactly... i did break one stud already, the nuts had no flange
so either way i need another, this isnt something that sells at a common ace hardware?
motoman399
my ace hardware has automotive studs.
you can also just use a long threaded bolt and cut the head off and use the threads. then you can just like use a pair of pliers to mess up the threads so it doesnt keep threading in. or if you really want it ill pull the studs out of my old water pump and send them to you.
badbob2121
well hey i appreciate the help, im gonna check out the local hardware shops, and if all fails i will pm you about sending them.. thanks again
motoman399
for sure man. good luck.
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
i have studs at my job. I forget the pitch and length of the studs tho.
badbob2121
well i went to ace and found them right away and worked great
thanks for the helps and offers :dblthumb:
ill have pics up in my thread soon
