Getting rid of non power antenna
khilgers
What are the alternatives to getting rid of the god awful antenna on my car? Are there ways of getting rid of it and still being able to use my radio. I know I've seen the little rood mounted mini antennas but what is involved with using those?
Emperor
I just unscrewed my antenna completely and radio comes in fine, not that I listen to it. But I did check.
astron
is a power antenna a viable alternative? I found a radioshack one on ebay for around 20 dollars..worked out just fine, pretty easy to install..only thing was i couldnt bolt it in very well, so i zip tied it..(hasnt budged a bit, worked great as far as i'm concerned)
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
the ones i saw on ebay didnt have a motor....
-Dan
daniel240
Car: cars/motocross
just pick on up at autozone i replaced my power one w/ a normal one and i cut it off to about a ft. and radio works fine.
nismofan14
I shaved mine and bought an internal antenna($20). It mounts in the upper corner of your windsheild, has a hot wire, ground, and then the plug for the receiver. Really small and looks better than the metal one sticking up on one side of the car.
astron
didnt have a motor? wierd..look harder....Yeah, autozone has them, your sterio shop should too, although mine wanted around 100 dollars for one.
runyun
nismofan14 wrote:I shaved mine and bought an internal antenna($20). It mounts in the upper corner of your windsheild, has a hot wire, ground, and then the plug for the receiver. Really small and looks better than the metal one sticking up on one side of the car.
hey nismofan14,
where did you find one for $20? I just had mine shaved off.. and the only ones I could find were about $50 :confused:
