Rex »
https://forums.nicoclub.com/rex-u6324.html
Tue Dec 23, 2003 10:20 pm
Ok, try this, remove the door panel/cover and try to make them "rattle". If you can, then it's not the door panel/cover, if you can't it's the door panel/cover and you just need to see about bracing/securing it.
If you can still make it rattle with the door panel/cover removed, then start applying pressure around the speaker to see if you can minimize or eliminate the rattle. If that works, you may simply be able to add some type of foam or padding between the edge of the speaker and the door/mounting. If not, you might try either a higher (passive) crossover until you get an amp, or you may even try to get some small rubber washers and put them between the speaker and the door to help dissapate the reverbirations of the speaker.
Let us know.
