Turbo 510 »
https://forums.nicoclub.com/turbo-510-u3954.html
Mon Jan 27, 2003 7:57 am
My Turbonetics T3/T4 was $635 complete. If you stay below 10 psi, you can run the 370cc 300ZXTT injectors along with a computer mod of your choice. I have a JWT upgrade and it runs like a stocker until you nail the throttle (then it has severe traction problems). If you run MSD 50 LB. injectors, you will need to fab a fuel rail (mine cost anout $15). You will also need to upgrade to a Mustang Cobra AFM that will read increased air flow above the max 5volts that the stock one will read. The computer also needs to be upgraded to understand readings above 5 volts and tell the injectors to feed the engine more fuel. If you are going with the MSD/Cobra set up, I would encourage you to build an appropriate bottom end to support the approx 400 HP you could produce (o-rings, forged pistons, forged rods, gridle studs, etc.) Remember turbocharging on a budget is cheap until you destroy your motor and have to do what you should have done in the first place.
