Getting ready to srpower the vert....Any suggestions????
need4gforce
Car: 180sx
I think the hardest thing will be making it stick!!
masterteque
Car: 1993 s13 convertible 1993 s13 coupe
Making it 5 speed is very simple.......
94_240sx
Car: 94_240SX
Isn't SR comes with 5 speed transmission already attached? So all you need to do is take out KA /w transmission and put SR in. That's it. I think it'll be even easier swapping auto transmission to stick on KA.
masterteque
You also need to install a clutch pedal, replace or cut the brake pedal, drill a hole for the master cylinder, run clutch lines and remove old shifter assembly....A little wiring mods and your done....But still very easy....
94_240sx
Car: 94_240SX
masterteque wrote:You also need to install a clutch pedal, replace or cut the brake pedal, drill a hole for the master cylinder, run clutch lines and remove old shifter assembly....A little wiring mods and your done....But still very easy....
Oh! That's what all our vert guys already know... Those things should be easy since you will take out the motor and trans.
masterteque
I was trying to helpful not condesending.....It seemed like this post was put up because some people didn't know what was involved.....
