Getting ready to replace power steering pump on 95 standard any tips?
jaeimwhy41
Car: 1995 Infiniti Q45
Hello all, I am going to be replacing the ps pump in the near future as soon as i get the part from mike and i was wondering if someone could point me in the right direction as far as what i will need to complete the whole process such as gaskets, what fluid do you recomend, bleeding procedure, etc. Yes i am new to the fabolous world of q45 repairs and could use the imput. Thanks to any one that can help.
James
silver2k2
Car: 1994 Q45 Ivory Quartz/Tan
Pretty simple jobRemove under body plasticremove bolts FSM will show you where
No gaskets needed just get 4 new copper washers
you might want to replace the ider pulley and the belt.
you also might want to replace the alternator and ac belt since you will have to take them off again to do it later
Its a good first project
turning it lock to lock holding 10 seconds each time will flush it
You will need 2 qrts of dextron III fluid
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Unless abused or fluid not changed, pumps seldom fail or wear out.
Check your hoses and their fittings. Are you going to flush the steering rack? If you have metal shavings or gunk from old failed fluid, highly recommended.
Many of us use M1 ATF, but use a conditoner for the seals.
I would consider belts and pulleys while you are at it.
jaeimwhy41
thanks for the tips silver & max...i can get the dextron III from advanceauto or autozone correct? also on the flushing aside from turning the wheel from stop to stop, is there a bleeder? or do i just hook the everything up, add the new fluid and turn the steering wheel back and forth? sorry if i sound like a complete moron but on this car i have come to realize that one must do everything the right way the first time or all hell breaks lose. find that out the hard way replacing the waterpump awhile back. thanks again.
p.s. i'm sure as hell the fluid has never been changed as with alot of other things i have found in the past year or so.
just checked advance autoparts they have valvoline max life dexron III atf... is this good? or should i find another brand?
Modified by jaeimwhy41 at 4:46 PM 6/15/2007
goody90q45
Car: 1992 Infiniti Q45 (sold)
Good time to change over to Synthetic (ATF). You'll definately have most of the original fluid out after pulling the pump and letting it drain while you put bandages on your hands (jk).
Jared- Are the crush washers available off the shelf at an auto parts store or a dealer only part? Good luck.
silver2k2
I got mine at napa autoparts
