Hoffman5982 »
https://forums.nicoclub.com/hoffman5982-u77367.html
Mon Mar 28, 2011 9:58 pm
To be honest, I would wait until you have more than a weekend to do it. Give yourself some time to clean the bay while the motor is out. That's just my recommendation though.
Anyways, make sure to have all of your fluids, new oil and fuel filter, and new spark plugs. How are you converting your harness? Are you doing it yourself or paying someone to do it. If you're doing it yourself make sure you have plenty of electrical tape, solder, and wire loom. If you are replacing all of the gasket,including the head gasket, go ahead and buy some ARP head studs If you have a way, do a compression test before putt the motor in.
When do my swap I bought easy 200 bucks in other random crap that I ended up needing. Unfortunately, I can't remember every single thing. If I remember anything else Ill let you know. Good luck
