I finish up class in a week and a half and while I should be working on projects I have other projects on my mind. I am planning on doing some serious work to my Q over the summer and want some insight as to a) what's the most important b) how to keep costs down (i.e. if anyone has things for sale, knows where to get cheap, etc.) and c) any other advice.
First of all here is all the information on my car. It is a 1990 Q45. It is a silverish blue exterior and a blue/navy blue interior. (the dealer report lists the color as dark gray with 'B' trim). The car currently has 247,900 miles on the odometer (original engine...new guides) and I should go over 250k by the beginning of June. This past August the transmission died on me (my second) so I had it completely rebuilt through Cottman Transmission and had a transmission cooler attached. The transmission has a lifetime warranty and is scheduled for a flush in August. Last August, I replaced all the rubber hoses, 6 fuel injectors, water pump and rear wheel bearings. Back in October I took my car to Major Infiniti to have a diagnostic done. The work report stated the following: Needs power steering pump Needs four-wheel alignment All power steering hoses leaking and boots Needs to replace Mass air flow sensor Needs to replace temp sensor, thermostat and fan
After this trip to the dealer I replaced the power steering pump w/ a slighty used one, replaced all four shocks w/ tokico blues and had a 4-wheel alignment done, replaced the MAF sensor w/ a slighty used one and replaced the thermal temp sensors. I also had my mechanic replacing the idling pulley on the alternator as it needed replacement. He also checked the hoses and said they were not leaking. Other problems with the car are the following: need a new armrest and glovebox, I need the center console cover as mine has the two holes drilled in for the car phone which i hate...plus it's old and has a stain on it. My sunroof does not work and has a slight leak toward the rear. As for performance issues the cruise control will not work and I think i have that narrowed down to the servo needing replacement. My car also seems very sluggish when accelerating...feels like it just needs to cough something up if that makes sense...just kind of feels congested. Also I need a new master cylinder as brake fluid is leaking.
I know this sounds bad but remember the car is about the pass the quarter million mark. I would like to know what you guys can help with as far as what to do, triage, pricing, advice, encouragement
Nick
